I would like feedback on what are the best parts for gaming in the mid $1600 ~ $1800 range here is what I put together thanks in advance ~ laszlo http://pcpartpicker.com/p/MGvPcf
p.s I need the 32gb ram for photoshop, streaming and editing, thanks again ~Laszlo
The H440 does not have a slot for an optical drive but you can still run a external. Otherwise the H440 is a great case, I have one and it is built solid.
Not bad. Although I really can't recommend the 980. It is too expensive. So much more than a 970 or 290X for like 5-10FPS more at 1080p and about the same performance at higher resolutions.
