Ok this is my first PC build and so far everything is good, as in the computer hasnt started on fire yet. I am not sure what to install, their are so many driver updates for the mobo/GPU/periferals, do i need to insatll all of the driver updates or just specific ones. Also i have tryed installing zone alarm free firewall for security twice and both times their would be a zone alarm box stuck in the buttom right corner and it wont let me uninstall the program, both times i had to completely wipe the OS and start over.
Windows 8 pro
AMD 8350
AMD 7970
ASUS M5A97
16gb Kingston hyperX 1866mhz
Any help would be greatly appreciated.
