I was just wondering if this would all work together as I am hoping to build this and it is my first PC build. I took inspiration from the recent budget build as you may notice with the processor.
My main concern is whether everything will fit in the case as I am not sure on the measurements thing and what cases are good for what.
I dont like the psu its not a great make and it only has 16A per rail. You can probably get away with it but i would invest an extra 20 and get something like
