Help First Gaming PC 1500$ Canadian
So pretty much I want to make a gaming PC.
The budget is 1500 or less. (Less = Better)
I want a great computer so if its cost the full 1500 or a bit more that is fine.
I want to be able to play games on high settings.
I live in Canada.
I have a build on pcpartpicker.com Link: http://ca.pcpartpicker.com/p/21oHx
If you could give me advice on what I should be looking for or what ill need that would be amazing.
If you could tell me your opinion on the build I have currently made that would be great too.
And helpful advice for a beginner would be perfect.
Thank you in advance!
its ok i guess but i really would bother with that CPU, id say get a fx 6300 or something of that kind. and for the ram you dont need it to be tthat fast.
you're throwing your money away with your ram. Also, i'd pick up a 4670k/gtx 770 or 760 sli at that price. i also really don't like that PSU. There are better options for the money.
I'm a canadian as well <3
What Rok Said. If you're not using this as a primary editing rig, then there's no point in getting 16gb of ram. Also spending that kind of money without having an SSD seems kind of strange
Intel option - http://ca.pcpartpicker.com/p/22yZX (3570k gives less heat and has more overclocking potential IMO)
AMD Option http://ca.pcpartpicker.com/p/22z3T (under budget with rebates)
