I'm upgrading my build and need help finding a solid motherboard, i want it to be future proff for 2ish years.
First i'll go over what i want to narrow down the list of motherboards.
1: SLI GPUs, I currently have 1 GTX 590 and i might get another to sli and hold me off before i get 2 690s down the road. The motherboard needs to be able to handle this nicely, decent spacing for air, altho the 690s will be water cooled.
2: PCI 3.0 Raid controller (I plan on getting 4 for now 8 down the road 120 or 240GB SSDs, depending on the prices after i get the motherboard) so a raid controller is a must and the motherboard needs to have a slot for it.
3: At least 24GB ram
4: This will be my CPU for now, i'm a medium overclocker so wont be trying to max out this cpu rly.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
Overall i'm building a Gaming PC that can jump from a CPU-GPU intensive game and not break a sweat.
My gaming is accross varying genres from Sim racing- FPS- MMOs and RPGs.
I'm an editor so multitasking is a must.
I would appreciate any help i get here, i'm not tech savy in this area enough to know what to look for.
price isn't an issue but below 800$ ofc, i also have no issues with w/e brand so long as it's the best damn thing out there.
Also any recommendations on PSUs to power this build would be great, especially if it's opt for w/e boards suggested.
