hey guys, I ahve the Rosewill Thor V2 and I want to replace the fans in it.
I am having a really hard time finding any good 230mm Fans, prefurably with Red LED's.. can someon help me out by linking me to some good 230MM red led fans?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007998%20600339700%20600035698&IsNodeId=1&name=Red
yeah they are out of stock but it gives you something to work from :)
review: http://www.overclock3d.net/reviews/cases_cooling/bitfenix_spectre_pro_range_review/1
reviews on new egg werent great, but the specs seemed great.
any I deas where I can get these at a similar price?
or maybe some other 230's,
I know you probably dont have experiance with this case, but generally. is it possible to fit 140mm or some other size fans into a place where 230mm fans go?
im also looking for some good 140mm Red LED fans. any Ideas?
im not really all that upto date with fans, im just typing stuff in google to get the info on them.
fan controller plus 4 120mm fans will yeild better performance and positive airflow
the case has a built in Fan controller with 2 Knobs. 4 3 pin connecters on each knob, not sure how many watts per channel. but it seems to be a decent amount.
the only reason I was avoiding 4 120's was noise and wires.
could you reccomend some 120mm fans that arent too loud? (preferably around 25db-a or below)
120 or 140 fans should be easy to find, in whatever color you want. Coolermaster makes decent ones, though I think Bitfenix's Spectre Pro line has somewhat better stats. Just going off memory though. Xigamatec has some too, and are the only company I know of that makes them with purple LEDs (in case you care).
