Help figuring out case fan size
I got ahold of an old pentium 3 computer, and to my surprise it actually turned on. The case doesn't have any manufacturer name or model number on it at all, but it's actually a pretty decent sized one that I plan on keeping around for any future projects. I don't have any kind of tape measure on me, so I was wondering if anyone would be able judge based off these pictures what size fans it takes? I've taken a few pictures of the fan slots directly next to a 120mm fan for size comparison. The side panel fan is really small in comparison, though the picture doesn't make it look nearly as small.
Side by side with 120mm
120mm overlaying the holes to give an idea of how much bigger it is
120mm next to side panel
From the looks I would say it is 80mm;
There were those times when you had the big on when it was 80mm :P
80mm for the side panel one or the back one?
The back one.. sorry the sidepanel pic had not loaded O.o
The sidepanel looks even smaller.. so could be a 70mm or 60mm I can not reliably say though. - and the hole layout and spacing around the meshed part looks realy wired actually. maybe a 60mm was meant to be mounted with the edges parallel to the case and the 70mm flipped by 45° ...
Side is 80, back looks like 80 and 92...
That old case design loves to put 80mm everywhere.
I till think the rear is 80 ^^ and the side is smaller....
tl;tr despite you mentioning it in the OP; a ruler will give you the most reliable answer.
Yeah, I just don't have one is all and it's hard to justify going out and spending 5 dollars on one for a one time measurement haha. I mean I'll probably have to, it just sucks cause chances are I'll never need it again haha.
Tapemeassure, ruler, back of a multitool, nothing? O.o
A piece of paper where you can look up the exact dimensions on wikipedia, than you can calculate how to fold it :P
Haha nothing. I'm not a very handyman haha literally the only tool I have in my house is a screwdriver for computer assembly. :P
rear of case looks like will take 80mm or 92mm fan, comparing it to 80mm fan on PSU
side panel fan looks like 80mm
suggest:
  1. get some string or a spare cable and compare size of PSU fan mounting holes against the others
  2. buy, borrow or salvage an 80mm fan - would probably fit in both locations
  3. get fan template pdf from mnpctech and print it at 100% scale
The rear and side have holes for 92 and 80mm fans
