The title says it all. I have tried many programs to crypt my first rat, but they are all detected by antiviruses. If it helps, the only antivirus it needs to get past is AVAST. I would appreciate it if someone would tell me how, or do it for me. Keep in mind I am 16, and do not have a job or money yet!
Thanks!
Aren't you simply supposed to code an encrypter after you make a RAT? You can use random public encrypters but those will obviously have already been detected, so you'll either have to pay someone to code a new one or code your own.
Any good crypt service will cost you money. The only good way is to buy the crypt software, and the FUD stub, and do it yourself. That's the only way you can guarantee its correctly done, and doesn't have someone elses RAT injected into it.
share pics of your sextortion victims please.
I'll crypt your stub for BTC.
