HELP! cpu stuck to heatsink
my vishera is stuck to my v6 gt, i cant get it off of it. I used arctic silver to put it on, since this is my first time build i put a little bit too much, now its stuck. any ideas on how to ge it unstuck?
picture: http://imgur.com/dqadza3
Just give it a twist it will come off.....you allso my want to check for bent pins if you pulled it out the cpu socket.
no bent pins and that did the trick, next time I wont use so much GEEZE. and thanks much
