Help / correct init-zram-swapping format
i need some help
when i set up my zram using
sudo nano /usr/bin/init-zram-swapping
i did it this way
the 2024 link fosspost
has it this way
an the 2023 link maketecheasier post
has it this way
my current config is the terminal view next to each posts listed config
the swapon -p 1000 /dev/zram0 line in my terminal view i did that as thats how it was in pop-os , im not sure what effect it has in ubuntu
but i want to know how it should be for ubuntu 24.04lts
should the init-zram-swapping
be this way with the zstd algorithm
#!/bin/sh
modprobe zram
Calculate memory to use for zram (1/2 of ram)
totalmem=LC_ALL=C free | grep -e "^Mem:" | sed -e 's/^Mem: *//' -e 's/ *.*//'
mem=$((totalmem * 768))
echo zstd > /sys/block/zram0/comp_algorithm
initialize the devices
echo $mem > /sys/block/zram0/disksize
mkswap /dev/zram0
or this way
#!/bin/sh
modprobe zram
mkswap /dev/zram0
swapon -p 75 /dev/zram0
or this way
#!/bin/sh
modprobe zram
mkswap /dev/zram0
swapon -p 5 /dev/zram0
an should the
echo zstd > /sys/block/zram0/comp_algorithm line be either above or below the
echo $mem > /sys/block/zram0/disksize line
an is it possible to add a force compression value like this compress-force=zstd:5 or somthing similar to that of the one used on my ssd drives btrfs filesystem
Ubuntu has a package zram-tools, configuration, say that 50% or physical RAM, in /etc/default/zramswap with a guide how to set it up, there’s a service zramswap.service that’s automatically enabled when you install zram-tools. I run it on all my Debian and Ubuntu machines.
K3n.
Also GitHub - systemd/zram-generator: Systemd unit generator for zram devices is in the ubuntu 24.04 repos.
