Well I have been running around trying to see what graphics card I should get, but I realized that no matter what I got my dual core CPU will bottle-neck. So I have since then decided to just take a complete overhaul of my system so I can get it all over with.
I have decided to grab a new CPU , to be specific I am getting an AMD AD7550KWOHJBOX quad core 100W processor. An MSI twin frozr 7850 graphics card. I am getting a new case but that is not relevent to said topic. I have a 430W PSU now, and I read up on some articles and people were able to get a CPU of almost exact power draw and the 7850 to run on a 420W PSU. I am wondering if I should just spend the extra 50 bucks on a 500W PSU or if I would be okay on 430, however in the best case scenario I would like to stay on 430 but I would move up if needed. The PSU is a corsair 430W bronze certified. Thank you - Cody
Should be fine, just don't expect to overclock much and dot run like 8 HDDs off it ha.
Any reason you don't want to run 500 or more. Rule I use is when my system is at max I like to hit between 65 to 80 percent on the power draw.
Well it all comes down to cost, i'm on a tight budget so the less I spend the better
The PSU is the most overlooked thing in a build usually. It's also one of the few things you shouldn't cheap out on. Why? Because unlike the rest of your PC the PSU is one of the few things that will be reused build after build. If you get a well built beast of a PSU you'll have it through many many builds. My last PSU was with me for 8 years and around 4 builds? It still works but its powering my test bench now. The only reason I stopped using it was because I wanted a modular power supply.
Um, okay? The PSU I bought for my original build (corsair 430W) was wayyy more power than I needed, I did this so I could do a big system overhaul, but the power situation looked a little dim, but I feel good about it now.
