Hi. I am not noobs. I was able to compiled Citra – 3DS emulator perfectly fine.
Dolphin is a problem… I compiled other emulators for macOS and don’t have a problem. I am not a noob but I have a problem. This is the first time I have a problem with Dolphin on macOS.
macOS Build Steps from https://github.com/dolphin-emu/dolphin and it doesn’t work… Here:
git clone https://github.com/dolphin-emu/dolphin.git
cd dolphin
mkdir build
cd build
When I type cmake … and it was in processing then I got an error. Here:
– Could NOT find OpenSLES (missing: OPENSLES_LIBRARY OPENSLES_INCLUDE_DIR)
– Could NOT find ALSA (missing: ALSA_LIBRARY ALSA_INCLUDE_DIR)
– ALSA NOT found, disabling ALSA sound backend
– PulseAudio NOT found, disabling PulseAudio sound backend
CMake Error at Source/Core/DolphinQt/CMakeLists.txt:1 (find_package):
By not providing “FindQt5.cmake” in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by “Qt5”, but
CMake did not find one.
Could not find a package configuration file provided by “Qt5” (requested
version 5.9) with any of the following names:
Qt5Config.cmake
qt5-config.cmake
Add the installation prefix of “Qt5” to CMAKE_PREFIX_PATH or set "Qt5_DIR"
to a directory containing one of the above files. If “Qt5” provides a
separate development package or SDK, be sure it has been installed.
– Configuring incomplete, errors occurred!
See also “/Users/azoreseuropa/dolphin-emu/build/CMakeFiles/CMakeOutput.log”.
See also “/Users/azoreseuropa/dolphin-emu/build/CMakeFiles/CMakeError.log”.
azoress-MacBook-Pro:build azoreseuropa$ make VERBOSE=1
make: *** No targets specified and no makefile found. Stop.
Is something missing with cmake … ?
No, I have everything in list:
pkg-config (brew install pkgconfig)
SDL2 (brew install sdl2
Qt5 (brew install qt5)
CMake (brew install cmake)
Help ? Thank you kindly.
