Hey all - after a bit of help choosing a new mechanical keyboard. Currently I am using a Gigabyte Aivia with Chery MX Red switches. The reason for the change is that I find reds too light.
Due to this I am looking at going Black or green switches. I though about Brown or Blue but they are the same as reds at 45g and blacks are 60g, greens 80g
If the Das Keyboard 4 came in blacks I would be sorted, but they only come in blue and brown.
So help me out if you can
Media keys a MUST
Backlighting preferred but not a dealbreaker
dont care about usb ports
dont use macro keys - dont care if it has them either
open to any brands that are not trash - no price limit either.
thanks in advance
