I’m planning to add storage to my current setup i3-12100, MSI Pro H610 MoBo, 1x 16GB RAM, 256 GB M.2 SATA SSD, 4TB External HDD. I’m thinking of adding 3 x 16TB HDD as my MoBo supports only 3 more (1 out 4 unavailable when using SATA M.2). My current OS is ubuntu server and I use docker to run my services.
I need storage to backup photos from phone, camera and some other family videos. Along with that, I also use it for Movies and TV Shows, some of these are rare / obscure content that I plan to permaseed. I wanted to use ZFS (raidz1) for the new drives.
Some people say zfs is overkill for media server and suggest using mergerfs with SnapRAID, is that true?
And what are some differences of using NAS OS like TrueNas Scale over Ubuntu server with zfs ?
I’ve never had the need to spin up a VM, so I didn’t consider proxmox, should I though ?
Please suggest an OS and filessytem for my use case.
Welcome to level1techs where WAYYYY too many professional nerds lurk
ZFS is the minimum here
perfect
Built to be a NAS first and foremost (it’s in the name), you can run docker containers and more on it but TrueNAS is a dedicated storage appliance.
Ubuntu has left a bad taste in my mouth too many times so I typically run Debian for baremetal or a real hypervisor.
Docker containers are vm’s with a shared kernel with the host (and will run natively on TrueNAS scale)
ProxMox is going to be the replacement for VMWare’s ESXI and Windows Server in the near future, but save it for a dedicated play rig. Establish your storage first.
I’m planning to follow wendell’s guide to setup VM on Truenas scale and run docker there as it doesn’t mess with host OS. Is that an overkill ?
Also, can I passthru intel igpu (UHD 730) for jellyfin ?
Does it make sense to add SSD pool just for docker app data as some applications suggest SSD for improved random I/O performance over HDDs. Would there be a tangible difference or improvement in HDD lifespan ?
Also does that mean the HDD pool spins down when no application reads/writes to it?
