So I am finding it difficult to deside between 2 cases Corsair 350d and the Air 540, i plan on running two 780's in sli really close to eachother on a Asus ROG Gene. So which would you choose?
The Air 540 has fans really close to the graphics cards but it seems a little too wide.
I would get the 350D just because the form factor is more normal. The air 540 just looks kind of strange. The cooling in the 350D should be fine as well.
