Hi guys, this is my first PC I'm going to build from 0 and I want it to be almost perfect and I'd like to get some piece of advices, so:
Budget: 1200 euros
Country: Germany, euros
- http://www.mindfactory.de/
Peripherals: Just a monitor - 1080p
Purposes: Gaming
Do you overclock or want to get into overclocking? I've no idea how to do it, but yeah, I'd like to overclock my components
Do you plan on going for custom watercooling now, or in the future? in the future, I suppose
OS. Do you need a new one? nop
If you Game-
What kind of settings do you like or what FPS do you want to play at? highest settings
What resolution will you be playing at? //or would like to play at. 1080p
What kind of games do you like to play? rpgs, shooters
What specific game will you be playing (if you only really play one) now I really want to play ac: black flag, far cry 3, i'm looking forward to play the witcher 3 and stuff like that, etc
I want a 240gb, but those ones are expensive, v300 costs 40 euros less than hyperx. 120gb hyperx costs 35 euros less than 240gb v300. Should I choose performance over storage?
I personally would stay away from closed loop water cooling. Something like the Noctua NH-D 14 performs very similarly and is cheaper and probably quieter.
I guess it's just preference at this point. Both the Noctua and the H100i will give you amazing cooling performance. Just check compatibility with big heatsinks and your RAM/mobo and see if they don't obstruct your airflow.
