I'm currently planing a build, I am a huge gamer. I spend most of my time on BF4 and League. I will also be doing video editing for youtube. I have decided on using the 1150 socket, but I'm stuck between two processors. I also will be wanting to overclock.
i don't believe you can overclock xeons (atleast the way most people overclock) i'm pretty sure they have locked multipliers, you can still overclock, but usually by not nearly as much
ok, I was leaning towards the Xeon, due to the price to performance, Also since its a work station processor I figure it would perform amazing for rendering videos. but not being able to overclock is sorda a killer because, then the processor is only relevent for so long, instead of being able to overclock and have it stay better longer
i7, xeon doesn't have gaming drivers and can't overclock. The i7 is stock about 15-20% faster than the Xeon and will be even more so when you overclock.
It's mainly up to you. If you're short on money, get the Xeon as it has better price/performance. If there's money aplenty, go grab an i7.
Unless you're doing some major data crunching, a Xeon wont do you as much good as an i7 would. If I was to go socket 1150 Intel then I would jump for the 4770.
What do you mean Xeon doesn't have gaming drivers? The haswell i7 and haswell xeon are pretty much neck to neck with each other, but yes the xeon can't be overclocked.
The xeon will be just fine. I have used one for gaming and i couldn't tell the difference at stock clocks. (2500k vs. E3 1220 v2 ). This xeon is based on the I7 just at a cheaper price due to the locked multiplier and lower stock clock. I don't see where you get a gaming driver for a cpu....
the Xeon is cheaper because its lower clocked and the multiplier is locked, you still can overclock it, if you play with bus speeds and voltages, but i would not recommend it if you not know what you are doing.. Also the Xeon does not have a igpu onboard, so thats also a reason why its cheaper.
In my opinnion the xeon is interessting if you like to play with virtualization VM-ware and that kind of stuff, because the Xeon´s have v-pro technology and VT-d. Which the i7-4770K does not have onboard.
But for gaming and video editing i would say go i7-4770K or the otherway arround AMD FX8350. Because the FX8350 is realy cheap and still does a good job in editing.
