Im looking to build a gaming PC that will run the latest games on the highest graphics possible, also i want the computer to be super fast and fast startup time, before i start im more of an intel fan the amd but open for suggestions,
-Must be quiet, fast, COOL, budget is anything 1.5k to 3.5k
Uses: gaming, surfing, movies, work, downloading,
Motherboard - i want to be able to run atleast 2 graphics cards and 4-8 slots for RAM, i am leaning towards the asus maximus range
Cpu - either i7 4790k or the 4930k which one do you recommend for gaming and speed
ssd - samsung 840 or 850 if there out yet minimum 250gp but i want the fastest start up time i can possible get, if so is it worth getting multiple ssds and running through RAID?
Graphics Cards - either the 780ti or the titan i want the highest graphics possble i can achieve, is it worth going 2 in crossfire or just one, which do you guys recommend 780ti or titan, (also could you list the fastest model please)
Case- mid or full tower, i want atleast 3 optical drive slots and a very attractive looking case with a glass side panel, but one that will allow water cooling or mounts for all in one
RAM- atleast 16gb but i want fastest possible
Cooling i would like to cool both my cpu and my GPU/GPUS which is best a custom or all-in-one that can do this, i want it to have no noise at all, but i want cooling temps for overclocking ( ive never done a custom before)
Power supply - gold or silver grade which can run all my parts min 850watt preferably one that has cables that are plug in for minimum cord tangling and clutter.
Thanks guys
<Build> <Gaming> <Rig> <Help> <gaming PC> <pc> <computer>
