hahns
October 3, 2013, 4:11pm
#1
Hi,
Looking to build a good enough PC to play games like F1 2012/13 and do some music track recording and editing.
I already have a HDMI 1080p led screen from Samsung that I will not change.
I'm limited to a mATX case (due to the size of my desk), and a budget of 1000$.
I a fan of AMD but they just don't have any good mATX mb (don't know if an APU is the way).
Please help,
Thanks
Hahns
Warpig
October 3, 2013, 6:26pm
#2
This machine should fit the bill. It will run any game out there on high to ultra settings, and there was enough room in the budget to add a half decent sound card.
It's difficult to find a decent AM3+ micro-atx mobo, so I went with Intel, and an even smaller M-ITX build.
http://pcpartpicker.com/p/1KD4v
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor . Probably a bit overkill for music editing, but I could fit in the budget.
MOBO: Gigabyte GA-Z87N-WIFI Mini ITX LGA1150 Motherboard . Z87 chipset, has Wifi if you don't have an ethernet cable.
RAM: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory . Typical Ram
SSD: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk . Relatively fast, cheap.
HDD: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive . Mass storage.
GPU: PowerColor Radeon HD 7950 3GB Video Card . All you need for 1080p gaming.
CASE: Fractal Design Node 304 Mini ITX Tower Case . A case to hold it all.
PSU: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply . Rebranded Seasonic. Great for the price.
hahns
October 4, 2013, 8:10am
#5
Thanks it sounds good.
One last thing since I'm a musician and will be doing some recording and editing is the onboard sound card enough or do you advise me to buy a dedicated one... if yes do I need to move from ITX to mATX format ?
Tks,
hahns
If you're doing some recording and editing, I'd suggest getting the Asus motherboard with the nice onboard solution:
http://pcpartpicker.com/part/asus-motherboard-maximusviimpact
