I've always wanted to make my own htpc system and i finally bought a tv for my room. So now is the perfect time to decide to make one. I've always been an intel user and have used nvidia for the past few years and now i think it's time to show some love for amd and so i will need help specifically with the gpu and cpu.
First i'll state what i want from the htpc. The system will be used quite a lot for watching stuff(and i watch a lot of things) however i wont be gaming as much on the htpc system. The htpc will be only used to play controller games like watchdogs and i only game for couple hours at a time. I also want to be able to control the system with a remote and i have no idea on how to make a remote work on a pc. i would prefer the system to cost between £500-£600 but i'm willing to go higher if i think it's worth it.
This is what i've picked from doing my research. I still havent decided on a case and was wondering if anyone knew any good cases that would look good next to a tv or on a shelf under the tv. also is the cpu good enough for me to upgrade my gpu in the future without having any problems and is 500w enough since i might plan to overclock in the future if the cpu starts to lag behind.
http://uk.pcpartpicker.com/p/2gpC8
On a side note. I'm currently streaming my videos from main pc using homegroup to the laptop which is connected to the tv. The thing is i dont want to turn on my pc every time i want to watch something on the htpc so how do i go about removing the hdds from the pc and connecting it to the network? if that makes sense.
Maybe remove hard drive and buy bigger ssd.
Wich games will you play if you will battlefield and that kind try FX-8230
well i'm definitely not going to be playing fps on it but i will probably play witcher 3 when it comes out. i've updated the list
small form factor (m-itx) with wifi a fast blower fan gpu to keep the case temps down and a low profile cpu cooler.
Plenty of hdd space and a semi modular psu.
What you picked out is fullsize ATX and is nowhere near a small http computer
http://uk.pcpartpicker.com/p/2h611
CPU: AMD Athlon II X4 750K 3.4GHz Quad-Core Processor (£56.39 @ CCL Computers)
CPU Cooler: Noctua NH-L9a 57.5 CFM CPU Cooler (£34.00 @ Scan.co.uk)
Motherboard: Gigabyte GA-F2A88XN-WIFI Mini ITX FM2+ Motherboard (£79.96 @ Dabs)
Memory: Corsair Vengeance LP 8GB (2 x 4GB) DDR3-2133 Memory (£53.49 @ Amazon UK)
Storage: Kingston HyperX 3K 120GB 2.5" Solid State Disk (£74.49 @ Amazon UK)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (£59.49 @ Amazon UK)
Video Card: HIS Radeon R9 270X 2GB Video Card (£159.59 @ Overclockers.co.uk)
Case: Cooler Master Elite 120 Advanced (Black) Mini ITX Tower Case (£31.97 @ CCL Computers)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply (£47.67 @ Amazon UK)
Total: £597.05
A cm 120 itx case siting next to a ATX case (with its sides off)
Im going to give 2 options: a mini itx option that wont be as powerful as the atx option but it is still a good choice if you want to have a small htpc case. Also i'll throw in the atx option if you dont care about how small or how large the case is.
Mini Itx: http://uk.pcpartpicker.com/p/2h6aS
Atx: http://uk.pcpartpicker.com/p/2h6o7
Thanks guys those lists really helped me out. Now i just have to think about whether i want to sacrifice performance for size. Such a hard choice :(
