Hello everybody,
after many years of working exclusively with notebooks it is time that I build a good PC for myself. My problem is that I got a little out of touch with PC hardware and hence find it a little hard to decide on the components.
Budget: haven't set a max yet, the cheaper the better, but it should not exceed 1000,-€
Purpose of new PC: developing software (.Net and Java for PCs; for MS Surface [Pixelsense]; Android development and security analysis); playing around w/ multiple VMs for various purposes; occasional overclocking and gaming; if possible the hardware should be supported by Linux as good as possible (I mean drivers) but my main OS is Windows 8
I already have a monitor, mouse and keyboard. I live in Germany (Munich) and I'd prefer to buy everything from Amazon.de
What I got so far:
CPU: Intel Core i7 4770K (http://www.amazon.de/gp/product/B00CO8TBQ0/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3JWKAKR8XB7XF)
MB :
a. Gigabyte Z87X-D3H (http://www.amazon.de/Gigabyte-Z87X-D3H-Mainboard-Sockel-Speicher/dp/B00CUCRKO0/ref=sr_1_6?s=computers&ie=UTF8&qid=1389826685&sr=1-6&keywords=LGA+1150)
b. MSI 7821-001R Z87-G45 Gaming (http://www.amazon.de/MSI-7821-001R-Z87-G45-Mainboard-Graphics/dp/B00D12OBEU/ref=sr_1_2?s=computers&ie=UTF8&qid=1389826479&sr=1-2&keywords=LGA+1150)
c. Gigabyte Z87X-UD3H (http://www.amazon.de/Gigabyte-Z87X-UD3H-Mainboard-Sockel-Speicher/dp/B00CXK59QK/ref=sr_1_3?s=computers&ie=UTF8&qid=1389826685&sr=1-3&keywords=LGA+1150)
It doesn't have to be exactly one of these three motherboards, but if you recommend something else it should be at least as good as these and should not exceed 150,-€
RAM: Crucial Ballistix Sport Arbeitsspeicher 16GB (1600MHz, 240-polig, CL9, 2x 8GB) DDR3-RAM Kit (http://www.amazon.de/gp/product/B007PNNTY4/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3JWKAKR8XB7XF)
I've read in many placed you shouldn't trust ram modules that use heat spreaders because they shouldn't need them in the first place and you can't make out the exact chips that were used and hence can't be sure about quality and such. So any 16 GB kit would do for me, I think, but I'm open to suggestions.
GPU: Zotac ZT-70401-10P NVIDIA GTX 760 (http://www.amazon.de/Zotac-ZT-70401-10P-Grafikkarte-Speicher-DisplayPort/dp/B00DKX0U0Y/ref=sr_1_11?s=computers&ie=UTF8&qid=1389829055&sr=1-11&keywords=geforce+gtx+760)
Without any particular reason I would have preferred an AMD card but couldn't find anything with comparable power at the same price. What do you think? Also, is it true that because this card is using the reference design for cooling, it will get noisy? Is there any good alternative that's quieter, has roughly the same power and doesn't cost much more? I'm willing to sacrifice a little horse-power for less heat and noise.
STORAGE: I never used an SSD (at the most hybrid drives) so I imagine a normal HDD would do but if I had to get an SSD I'd prefer a reliable one that doesn't need to break any speed records. If you think an SSD isn't necessary for my needs, what HDD would you recommend me? (It should be at least 2TB)
PSU: totally lost!
CASE: totally lost here too. I don't want anything fancy (I mean w/ lights). If the components turn out to be loud than I guess a case that's well insulated and doesn't transmit vibrations would be advantageous. I don't plan to ever use more than 3 HDDs + an optical drive(maybe).
Just out of curiosity: did anyone notice any improvement in network latency with the Killer nic?
Thank you very much.
