Help Building a Gaming Pc!
I don't know if anyone can help but I want to build a PC or buy a laptop that can play Day Z on decent settings.
My budget is 400-600 dollars.
do you need os and monitor with it
and or a optical drive?
and i dont think its really that possible to build a pc like that but i guess if u want crap parts maybe you can play on medium but im not really sure :p
$400-600 is easily doable
A10-5800K + 8GB DDR3 2133, cheap HDD, cheap case and PSU
lol the thought never even crossed my mind of choosing an amd processor >.>
i would have definitely said yes to that lol thanks for pointing that out
I was able to put together a pretty sweet system for 600$
http://pcpartpicker.com/p/uKjA
This will let you max out almost any game on the market, and will greatly outperform an APU build.
No. I got my tv and windows vista.
Thanks but the is there a decent GFX card that will play games on low-medium settings? Because  I don't need to max BF3 or Crysis 2. I just want to be able play games.
@Matman24
Indeed an excelent solution for $600. Will play pretty much all recent games maxed out at least 30fps.
