I am looking into build my own gaming pc around $600
what would you suggest for a build
Thank You
Thank You
I would recommend this build here from Austin Evans
www.youtube.com/watch?v=SfGE4i_A6E4
http://pcpartpicker.com/p/2Dbwc -It comes to about $660, before rebates, combos, and codes and then $620 afterwards.
This is basically the same build as above, but with an improved motherboard and a better CPU, which should last you longer and not have to upgrade them unlike the method with Athlon X4 750K/cheap mobo where, in 6 months you have more cash you will just upgrade it.
I did a little shopping and came out with this
http://pcpartpicker.com/p/2yHlS
Is it good or bad, what should i change
I prefer Jetix's build more.
The R9 270x will perform better than the 660, btw.
I agree with Some tech noob, about the 270x out performing the 660, it's also newer and has some better features. Though i did realize i forgot to add the CPU cooler and the one you chose is great for the money and this budget!
Hyper 212s all around. Great cooler for the price.
http://pcpartpicker.com/p/2EgYp
that motherboard won't last long with a power hungry 8350. this would be much more reliable:
http://pcpartpicker.com/p/2Ehmq
I also opted for faster RAM, a nice CPU cooler, and a modular PSU.
I accidentally bought the Asu. M5a97 le
I also want a cheaper gpu
The Asus M5A97 LE won't get you very far as far as CPU goes.
GPUs less than this price will have a large drop off in performance, but if you wish:
http://pcpartpicker.com/p/2Fcea
^ will perform a lot worse compared to the build I suggested earlier, but that motherboard can only handle up to a 6 core CPU(no overclocking either). A GTX 660 can work for most games at around medium settings.
I wasnt really sure what was going through my head with the cpu and gpu at the time but ill stick to a fx6300.
http://pcpartpicker.com/p/2Fg1o
Also Im trying to find a descent case and power supply thats not too expensive.
I tried to lower the price on the build, and still have it work. Your RAM was quite expensive(doesn't make a difference, really). The Source 210 Elite is a great budget case.
Also, the CX600 is the same price as the CX500 right now.
http://pcpartpicker.com/p/2FlgH
