http://pcpartpicker.com/user/KobeTevaga/saved/2gHx
How is my build? Anything I should change? My budget is $750. I'm mostly going to be gaming and some minor coding on it. Thanks in advanced :D
For gaming with such a budged id go with a cheaper non APU cpu, cheaper ram and a dedicated gpu. Even with fast ram modern games will barely be playable in 1080p on the lowest settings with an the 6800.http://pcpartpicker.com/p/1AVSw 650, should be well under 750 after taxes. The 7770 is enough to play games about mid 60 fps 1080p, you can always upgrade later on if you want more.
Just a tad over $750.
http://pcpartpicker.com/p/1AVRk
