Help Blue screen
Everyone my windows does it update when I shut down. I get a bluescreen and have to use my restore point, And it happens again. I ran a viruses scan a few times and It has found nothing. What else can It be?. And on a sidenote I'm having a HUGE cpu hog with Csrss.exe.
Windows 7 btw.
get a program named bluescreenview and post the blue screen code that appears everytime your pc crashes
http://i.imgur.com/FYQWz.jpg?6541
That?
exactly
Ok.
well here is my diagnosis,first it could be a driver issue so it would be an excellent idea to update your driver,second csrss.exe ''is the main executable for the Microsoft Client/Server Runtime Server Subsystem. This process manages most graphical commands in Windows. This program is important for the stable and secure running of your computer and should not be terminated.''
also make sure csrss.exe resides on windows\system32,because it could be a computer virus disguised as csrss.exe and hog up your cpu,also creating the blue screens
Hm What's the best way to find it thenIf it is a virus. I ran a scan a few times and nothing pop'd up.
well at first i would update the drivers to try to rule out the bsod,because csrss.exe is the main executable for the microsoft client/server and tempering with it could make your system unstable. so we need to make sure csrss.exe is the main cause for your problems
