HELP! ASUS Thermal Radar V1.01.29 setup.exe failed
Hey,
This is the first time something like this has happened to me, I try to run the setup.exe and my pc comes up with the it's stopped working bs, I don't know if it's something to do with X64 or not. It says its supported for 8.1 but I know to take that with a grain of salt....
I'm running windows 8.1 on a AMD 8320 on a ASUS Sabertooth 990fx r2.0
First off, is the thermal radar the one off the disk that came with the board?
If yes, go to Asus's website and download the latest everything for your board (the only purpose of those disks are to get your network drivers).
If no, try to run it as administrator
Nah I downloaded it from ASUS but its still a no go
Try running it as admin or compatibility mode
thanks, compatibility mode worked
