HELP! and I NEED SOME CLARIFICATION!
this might be a cross topic thread but it revolve around changing motherboards
ok today i picked up a desktop with some components which i have swapped to my current desktop NAMELY a mobo and CPU, ive gone from a I5-2500 and a gigabyte P67A-UD3-B3 to an I5-2500K and an Asus P8Z68-V LE.
so heres my situation in the other machine windows boots up unstable do i have to go with a fresh install again? cause some say otherwise.
My MAIN CONCERN is in my machine im getting no video output out of my gpu (7850OC) or my new motherboard even though everything seems to have powered up fine. Although it powers up, shuts down and then powers on again which is a worry for me
people on this forum have been good so far hope they can help again, would be much appreciated
anything i need to add let me know
Sounds like the motherboard is trying to fix some issue that it found during the POST by rebooting. See if you can get it to load into the BIOS. From there you need to check and see that the memory that you've installed is being recognized and is running at the right speed in the appropriate slots. If it isn't, fix it. Memory is one of the most common problems with builds, mainly because it is so readily damaged. You may also consider removing them from their slots and carefully cleaning the slots and the memory sticks with a soft nylon toothbrush to remove dust. After that, concerning the video output (as I'm assuming you get output via the iGPU when the discrete card isn't installed) you will have to change your default video output device within the BIOS from the integrated to the PCI-e source. If all that checks out and you can boot into Windows, you'll want to update drivers and possibly update the BIOS as well. Just remember when you do that the settings may need to be changed again.
ok cheers but i cant do half of this stuff as i have no video output at alll
you need a fresh install. the chipset drivers for your previous board is interfering with your new one. duh
disconnect all hd's and other components other than the ram and video car and see if you can get into the bios that way.
ok sweet i managed to get the video working again an ill do a fresh install of windows, thanks for clarification of windows install as looking around i saw some people were able to get it to work when switching, under some cercumstances
thanks
Well, I've never had an issue with my chipset drivers preventing me from booting on a different computer, so I didn't suspect that they may have been the issue. I've been swapping HDDs between computers for years without any kind of problem like that. Obviously the new drivers have to be installed to replace the use of the generic ones, but those will at least allow the device to boot. Hmm...
Maybe it's because I connect my monitor to the motherboard's integrated graphics solution for the initial setup before I install the GPU, then I switch the source over, power it off, plug in the GPU, switch the connection and call it a done.
I've never had to perform a fresh install to make a computer boot. Ever. I can't say that it isn't a possibility, because I still don't have nearly enough experience with all of the various brands of components, but it just seems doubtful to me.
