Help I used AMD driver uninstall software and deleted all my driverS!! no i can't use my keyboard and mouse!! What to do??
ya, had that issue with the new drivers while doing several updates at the same time. I took the easy way and did a system restore. Then carefully installed just amd drivers. With mine i had key/mouse in bios but not once i loaded into the the os.
Well this is the thing, I have disabled system restore and no way I can restore it from a previous point. Is there any other way to go by this situation?? if possible I would not like to do a fresh OS install.
thanks,
Atobe
