Hello,
I'm in need of help and anvice, I'm no master of computer building, I'm not even a novice, but I some what understand the concept of "what = better".
Edit: Buying from Newegg.com NEW (All the Item numbers if entered into the search will take you directly to the part)
That being said, I have a spread sheet with 3 pc builds:
https://docs.google.com/spreadsheet/ccc?key=0AkglWu09tnJ4dGxXWnlHWjhkMWFYMHNwenBGUk9zNWc#gid=0
1st. Programmer (Brandon [Me])
2nd. Visuals* (Erick)
3rd. Audio* (Mario)
I was hoping someone would be able to advise me as to what is necessary and what is just overboard, mind you, my pc (emphasis on "personal computer") is going to also serve as the test pc aswell (we're going to run our games on it to test them) so,
1st PC: Programming, Testing, Gaming, Daily use.
2nd PC: Visuals; Art, Animation, 3D Modeling, Daily use.
3rd PC: Audio; Sound, Music.
Those are what the computers are going to be used for no more no less.
For my computer I want to run 1080p at most and run high framerates, onhigh end games (skyrin, farcry 3, Saints Row the third).
The other computers need to be able to do their jobs, gaming performance does not matter, AT ALL with the audio pc, but with the Visuals PC it needs to be able to do simple gaming, seeing as there's going to be alot of rendering, might as well allow it to play some games.
Other than that there's nothing more to say, there are a few things I am NOT going to change:
The casing
The operating system (as if I had to say it)
The mouse and the Keyboard
Other than that have at it, but please no "Noob shaming" this is my first time, so if It's bad I do apollogise, if it's good for a first time then cool, I tried my best :)
Thank you for putting up with me and my non stop rambling, all help is appreciated!
Thank you,
Brandon Hernandez
TL;DR
Look at link and tell me if it's overkill or not
