I just payed $140 on Star Citizen only to realize that my GPU isn't compatible. Yeah a stupid mistake I know, but I've never had to worry about my minimum system requirements before even though all I own is an aging gaming laptop.
So I was hoping that you would do another "budget build video" geared towards Star Citizen.
Help me or I will put 50 corn-dogs in a burlap sack with 1 fish and let them rot and get really moldy, then I'll hide them under your couch in your house in the forest.
-Sap-
That threat will really catch their attention.
get a used 2600k, 2700k, 3570k, etc. whatever you can get a good deal on.
8 gb of ~1600 ddr3
whatever cheap ASUS, MSI, Gigabyte or Asrock motherboard has good reviews
r9 280x or whatever video card tickles your fancy. Perhaps you can get a used 7970 for a good price.
whatever hard drive configuration you feel like (get a ssd!)
for the case get whatever looks cool to you with good reviews (the key thing is that the reviews say its easy to build in)
for the PSU get a 650-750w bronze certified, again whatever is cheap and has good reviews
it's all about what is a good deal in your location and what stores are around you. Even more so if you live in the states, Logan's build videos use amazon which is good for the US, but in Canada for example everyone uses Ebay or other stores because Canadian Amazon is trash.
