I just need some confirmation of what I have will work. I'm trying to get some old speakers working with a car sub and I want to make sure that I have found the correct amp for what I need.
So what I have:
1) Sub: Diamond Audio d3 10" (I am pretty positive it is the 40-400w 2 ohm version, and do not want to tear apart the homemade box it is in to be able to check exactly which model it is).
2) 2 Satellites: 35 watts/channel @ 5% THD, 1KHz, two channels driven
My buddy and I think that this should amp should be good for what I need, http://www.crutchfield.com/p_543X75/Russound-X75.html?tp=180
Will this work and not blow everything up? Thanks in advance!
