Hello everyone!I have a problem with my first build gaming pc!It keeps turning on and off ,
First I build it outside the box.. I installed the CPU,FAN,GPU,RAM then plug the 24 pin,8pin and gpu pin of the psu. turned it on using a screw diver and I got the same problem, on and off...This is my first build so I have no idea what it is, For starters I ignored it and install it inside the case thinking it will be okay after I plug in everything.I think I plugged in every cables right ,pushed the power button on the case then there it goes again!On and Off!!
Im a newbie but my theory is the problem was either on the motherboard, CPU,GPU, RAM or PSU...since I had the same problem after building it outside the case. Im leaning towards a defected PSU or damaging the Motherboard without knowing.I want to know if anyone out there know what the problem might be..
Here are a few videos of my first build.
www.youtube.com/watch?v=L5xroJ2ZZ3M
https://www.youtube.com/watch?v=kw3dacZNxtY
