Help $1400 haswell gaming build
I was thinking an i5 4670k and a 660ti/760ti (if it comes out any time soon)
I would also like an ssd cache for a 1tb drive if possible.
What would be the best motherboard to go with this which will probably need sli support as i will probably add another gpu in the future.
I would also like to include an aftermarket cpu cooler as I would like to have a go at some mild overclocking. And btw that price must include a monitor, I was thinking 24" and it doesnt need to be 3D or any of that stuff.
I am from the UK.
I will be mostly playing some indie games and the AAA titles such as the upcoming BF4 and the current crysis etc. I am happy to run these games at high at 1920x1080 if possible with the suggested gpu.
I wont require speakers, mouse, keyboard etc as I have them from an old pc. Dont need an optical either I with take that from my old system.
Any help would be much appreciated.  =)
4670k+msi z87-gd45 = 319$ @ newegg
http://promotions.newegg.com/intel/13-2602/index.html
nzxt tempest 410 case = 59
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146081
nzxt hale82n 750 watt power supply = 89
http://www.newegg.com/Product/Product.aspx?Item=N82E16817116019
gskill ripjaws 2x4 8gb cl/8 1600mhz memory = 72.99$ - 10% with promo code EMCXPWM35
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
phanteks cooler ph tc14pe_bk cooler = 80$
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709011
kingston hyperx 3k ssd 120gb = 129$
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239045
seagate sata iii 2tb hd = 79 with promo code EMCYTZT3649
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148834&nm_mc=EMC-EXPRESS062213&cm_mmc=EMC-EXPRESS062213-_-EMC-062213-Index-_-InternalHardDrives-_-22148834-L01A
asus sata dvd/cd burner = 17$ with promo code EMCXPVX43
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
that's like $840~ ... you could get a different cooler or get 16gb of ram instead.. if you got more you'll need low profile ram so you dont bonk the large ass phantek cooler on the first dimm slot.. you can figure out what video card or monitor you want.. i suggest a radeon 7000 series cause it has balls. i use a vizio tv so i cant really reccommend a good monitor.
Why only Newegg?
newegg is NA/CA only no shipping to other countries
yeah i didnt think about that gigabuster, i dont know where he lives..
brennan.. newegg rocks?
newegg is fine, it ships to my area, I will probably just by a benq 24 inch, and as that is only $840 ill probably switch cooler for h80i and get a gtx 770. Thanks for all the help guys, much appreciated!!!
Overpriced, generally. Amazon has a much better return policy and generally lower prices.
ill have a look on amazon right now, thx for the advice
