I want a case around $100 probably and i have a noctua NH-D14. I need a case that will fit that and i would prefer it to have a window, but isn't necessary, thanks.
Define R4 with a window is currently $109. Have it personally. Amazing case. Without a window it is $79.
Phanteks Enthoo Pro is $99.99 and was arguably the best all around case of 2014.
NZXT H440 is a great choice to. It is around 100$ and fits D15 with no problems, so D14 will have a breathing room.
Enthoo pro is also a great choice. Not as silent as R4 or H440, but still a great choice for cooling, cause it is open as hell...
If you can find Fractal Design Arc Midi R2 - think of it as better cooled R4, and with D14 will be almost as silent.
I'm gonna vote for the r4. Case is solid and will keep everything nice and quiet.
I like the Define R4 and my personal favorite right now the NZXT H440
+1 for R4 or R5 if you got the money.
ENTHOO PRO ENTHOO PRO ENTHOO PRO
got the 500R on newegg for a pretty good deal;$5 newegg card, and 20mail n rebate and only $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139010
but thanks for everyones reply
coolermaster lanbox haf-xb
http://www.coolermaster.com/case/lan-box/haf-xb/
You can fit everything, it has great ventilation and is ready for cable management.
I have a NZXT 530 with Phanteks PH-TC14PE, which is arround the same size if not bigger then the NH-D15. so it fits realy well. plenty of space left. You can also choose 3 color options. Black / White / Red
https://www.youtube.com/watch?v=UexkSEhn4oU
