Not sure if blog is the correct place for this but I figured since its nearly standard in Kernel 4.18 id share a small tip that I use to keep myself from being tracked by means of a MAC address or hostname.
I am also working on a random UUID generation everytime I connect but it is still a WIP
You are forewarned that this comes at the cost of convenience and you will be required to relog or accept the hotspot terms and services on every connect. I value this though so Im fine with these consequences.
Also it has the advantage that in a school or university network your device is literally new on each connect. Depending on how IP addresses are issued and DHCP leases are renewed this can become problematic but at my network it works.
Now before we start if by the time you reach the end and you have a suggested improvement. I would love to hear it
Bearing this in mind lets start
Start by running the following command. I am in fedora so nano is present
sudo nano /etc/NetworkManager/conf.d/00-macrandomize.conf
This file will be blank so place the following inside.
[device]
wifi.scan-rand-mac-address=yes
[connection]
wifi.cloned-mac-address=random
ethernet.cloned-mac-address=random
connection.stable-id=${CONNECTION}/${BOOT}
note: The stable setting is useful to get the same IP address from DHCP, or a hotspot portal might remember your login status based on the MAC address. With random you will be required to re-authenticate each time. I like this setting
Now you will want to keep your hostname randomized as well to avoid tracking so here is how you do this.
sudo nano /usr/bin/newhostname
#!/usr/bin/env bash
# Description: Generate and set a random hostname on Fedora
# Requires packages "SED and AWK"
__set_random_hostname() {
local new_hostname=$(head -n1 < <(fold -w8 < <(tr -cd 'a-z0-9' < /dev/urandom)))
# set new hostname
hostnamectl set-hostname "$new_hostname"
# set new hostname in /etc/hosts
sed -i "2 s/^.*$/127.0.1.1 $new_hostname/g" /etc/hosts
Make it executable:
chmod +x /usr/bin/newhostname
Make it run at startup:
sudo nano /etc/systemd/system/newhostname.service
Place in this file
[Unit]
Description=Start Fedora 29 with a different hostname each boot
Wants=network-pre.target
Before=network-pre.target
[Service]
ExecStart=/usr/bin/newhostname
Type=oneshot
[Install]
WantedBy=multi-user.target
Now enable your tweaks and restart network services
sudo systemctl enable newhostname && sudo systemctl restart NetworkManager
Have fun and enjoy!. Realize there are some inconveniences that this will create!
