Edited this to be PSU as it seems it’s the culprit.
I have a 1080 Ti with a Corsair H105, so the temps are never above 30°C it seems.
But when gaming and streaming (with CPU encoding) I get heavy stutter for a while, and frame rates goes from around 150 down to 12-20, and after a while it goes back up.
And when I use Kombustor to stress the system, it worked easily for 20 minutes and never went above 30°C, and in Folding @ Home with the power setting set to full power, it works for a while, and temps are fine, then my monitors lose signal and go black, but I the system keeps running and it keeps folding at least with CPU (I hear the fans still running at high RPM), cause I have to force it off by holding the power button down until it turns off to make it work again as I don’t want to wait for too long in this state to see if the monitors get signal back.
I also have heat sinks on the RAM and VRM on the 1080 Ti, and there is a fan on the NZXT Kraken G10 that blows across it, and the case has great air flow, so I don’t understand what’s wrong here. There is also proper contact with the GPU and cooler, with proper amount of thermal paste. I used the original factory applied paste first, then replaced it to se if it helped, but it still happens.
I have the Corsair AX860i that power my system, which is the 2950X and the 1080 Ti. I assume it can deliver power enough for the system even if I run Folding @ Home with full power.
Update:
I thought it might be related to power (which it might still be for all I know), so I added another cable so one just uses an 8 pin and the other just the 6 pin part. But it still happens. Not even sure that would help in any way. I do see the card use up to at least 262W, but temps stayed below 33°C (I moved things around a bit and it’s now exhausting at the top instead of getting fresh air from the front, so it’s a tiny amount hotter, but still far from too hot). The CPU uses around 160W I think, and stays around 58-62°C.
