Heatsink Help : Hyper EVO 212
Hey TekSyndicate community. I have two little questions for you guys.
1st.     I just bought all my parts but I'm pretty new at building computers and I'm confused about installing my CPU heatsink. I bought a Hyper 212 EVO heatsink but I don't know which way to point the fan. Should I point the fan towards the front of the case? Or the back of the case?
2nd.   I am really confused about installing a wireless adapter into my computer. I have bought a Rosewill adapter that goes in the PCI slot but I need somebody to confirm that's all I need to do. Here's the link to it : http://www.newegg.com/Product/Product.aspx?Item=N82E16833166021 . As far as I know, I plug in the adapter into the PCI slot and once I install Windows 7 it will recognize the adapter and automatically ask me which network to connect to. Is this correct or is there something else I need to do?
Thanks for the help in advance. :D
1. I would have the fan on the front side of the case, but oriented so that it is PUSHING air through the heatsink.
2. All you need to do is plug it in to the PCI-E slot, literally nothing more. IF Windows doesn't recognise it then you might need to install some drivers that probably came in the box.
Thank you for the info on the wireless adapter. Sorry if I wasn't clear,  I meant the fan ON the heatsink. Should I point the fan on the heatsink towards the front of the case. That's what people seem to be doing.
Fan in the front blowing towards the back( push configuration )
Will pulling not work?
It's not very efficient, but would still work.
Mine pulls because it is very close to the vents in the top of my case and seemed to make sense to pull it out the top. If I add a pusher do they make a y adapter so I can run 2 fans off my mobo cpu fan pin?
Push+Pull isn't worth the extra money on these budget CPU coolers.
But yes, they do make fan splitters.
The correct airflow in a typical ATX-like tower has the air entering lower front, and exiting upper rear.
The CPU fan is best mounted on the front side of the heat sink, pushing air through the heat sink toward the rear.  Just like Remington said.
There are other ways to arrange air flow in a tower, this is just the usual way.
I just saw a vid on youtube showing a high pressure fan pulling. It made sense to be able to dust off the cooler on the bottom and not have to take off the fan to be able to dust it off.
