Heat issue
I downloaded CPUID to see if my ram was running at the correct speed, and I noticed two things (keep in mind, I haven't changed a single thing in my bios outside of setting my optical drive to the main boot source for windows when I was first installing it)
1) My corespeed was jumping up to 4.2 gig, I have a 3770 non K, so the turbo should go to 3.9 at max, and be 3.4 regular speed.
2) My ram is running at 686.8, which if I have done my research means it's running at 1373.6 instead of the 1600 that's listed for my ram.
I decided to go in and look at the ram settings, and I noticed it was set to 1372 or something close to that, and none of the speeds were an even "1600" as my ram is listed so I figured setting it to "auto" would suffice.
About, 25 minutes after having my computer on, my HWmonitor (I think it was HWmonitor that alarmed me) popped up in the bottom right hand corner saying my motherboard was at 124 degrees centigrade. I then immediately shut my computer off and gave it 10 minutes to cool down. I turned it back on, went into my bios and my temperature was normal, and I turned my ram settings back to the 13xx setting and booted up my computer.
Once back into windows, I opened up HWmonitor and have been keeping my eye on it, but I noticed a couple of things, the temperature "AUXTIN" (I have no idea what this is) is bouncing between 2c and 127c and my "TMPIN4" is bouncing between 63c and 127c. It doesn't change to anything other than those two temperatures, and my ASUS monitor shows my motherboard at 23c
So I guess my questions are, why would changing it to "auto" cause something like this? Is it just HWmonitor bugging out? Is "auto" a really poor option for your ram? And why is my CPU acting as if its overclocked? I looked at the um, I think they're called multipliers (I have the non K so they're locked) but they are set to manual and each one is set to "41". I do not recall setting these, is it just the UEFI bios "Normal" setting in the "beginners" options that set them? And how would I go about setting my ram to the proper speed?
Mobo: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131837
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116502
Ram: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231428
It is apparently my ASUS temp monitor giving me the temp warnings, it just popped up as I was looking at it saying my CPU was now at 124 degrees centigrade, or 120 something anyway, for a split second, then it went immediately back to 27 degrees.
Would it be wise to run prime95 for a bit to see if the temps get out of control?.. I'm not really sure what steps to take to make sure everything is okay.
I also thought I should include these logs from the asus monitor over the last couple of days
[01/06/2013 at 07:04 am] +3.3V 4.080 Abnormal
[01/06/2013 at 07:05 am] +3.3V 3.392 Normal
[01/06/2013 at 07:47 am] +5V 5.600 Abnormal
[01/06/2013 at 07:47 am] +5V 5.000 Normal
[01/06/2013 at 02:49 pm] +3.3V 4.080 Abnormal
[01/06/2013 at 02:49 pm] +3.3V 3.408 Normal
[01/06/2013 at 02:58 pm] +12V 0.000 Abnormal
[01/06/2013 at 02:58 pm] +12V 12.192 Normal
[01/06/2013 at 05:25 pm] CPU -1.0 Abnormal
[01/06/2013 at 05:25 pm] CPU 28.0 Normal
[01/06/2013 at 06:32 pm] +12V 0.000 Abnormal
[01/06/2013 at 06:32 pm] +12V 12.192 Normal
[01/07/2013 at 03:40 pm] +3.3V 0.016 Abnormal
[01/07/2013 at 03:40 pm] +3.3V 3.408 Normal
[01/07/2013 at 03:45 pm] +5V 0.000 Abnormal
[01/07/2013 at 03:45 pm] +5V 5.000 Normal
[01/07/2013 at 04:13 pm] +5V 0.800 Abnormal
[01/07/2013 at 04:13 pm] +5V 5.000 Normal
[01/07/2013 at 07:39 pm] MotherBoard -122.0 Abnormal
[01/07/2013 at 07:39 pm] MotherBoard 22.0 Normal
[01/07/2013 at 11:53 pm] MotherBoard -1.0 Abnormal
[01/07/2013 at 11:53 pm] MotherBoard 22.0 Normal
[01/08/2013 at 12:53 am] Vcore 0.000 Abnormal
[01/08/2013 at 12:53 am] Vcore 1.088 Normal
[01/08/2013 at 01:08 am] +3.3V 1.120 Abnormal
[01/08/2013 at 01:08 am] +3.3V 3.392 Normal
[01/08/2013 at 02:24 am] +5V 0.000 Abnormal
[01/08/2013 at 02:24 am] +5V 5.000 Normal
[01/08/2013 at 02:45 am] MotherBoard -1.0 Abnormal
[01/08/2013 at 02:45 am] MotherBoard 23.0 Normal
[01/08/2013 at 02:57 am] CPU -1.0 Abnormal
[01/08/2013 at 02:58 am] CPU 41.0 Normal
[01/08/2013 at 03:49 am] +5V 10.200 Abnormal
[01/08/2013 at 03:49 am] +5V 5.000 Normal
[01/08/2013 at 04:58 am] Vcore 1.896 Abnormal
[01/08/2013 at 04:58 am] Vcore 1.008 Normal
[01/08/2013 at 05:07 am] MotherBoard 118.0 Abnormal
[01/08/2013 at 05:07 am] MotherBoard 23.0 Normal
[01/08/2013 at 05:30 am] +3.3V 0.000 Abnormal
[01/08/2013 at 05:30 am] +3.3V 3.392 Normal
[01/08/2013 at 08:22 am] +5V 8.520 Abnormal
[01/08/2013 at 08:22 am] +5V 4.960 Normal
[01/08/2013 at 12:14 pm] +3.3V 4.080 Abnormal
[01/08/2013 at 12:14 pm] +3.3V 3.392 Normal
[01/14/2013 at 03:00 pm] CPU 113.0 Abnormal
[01/14/2013 at 03:00 pm] MotherBoard 124.0 Abnormal
[01/14/2013 at 04:25 pm] CPU -124.0 Abnormal
[01/14/2013 at 04:25 pm] CPU 30.0 Normal
Sorry for the block of text, it looks like it's been doing it for a couple days, I've just never seen the warnings pop up. So this is completely unrelated to the ram setting I changed I guess, and as I was typing this, yet another pop up
[01/14/2013 at 04:40 pm] +12V 24.480 Abnormal
[01/14/2013 at 04:40 pm] +12V 12.192 Normal
Are these volt fluxuations normal?
--edit sorry the logs went all weird and out of sorts, I don't know how to fix them
I went into my bios, and I set everything to default, and it took about 4 or 5 tries in the BIOS before it actually stuck, and then that also set my ram to it's proper speed of 1600 mhz, and it now shows my CPU only going up to it's maximum 3900mhz, which for me is fine, I had no intent to overclock hence why I got the 3770 non K, I'm also on the stock cooler, which would scare me to overclock with this.
My temps in HWmonitor are still wonky, I'm waiting for the asusmonitor to pop up again, the HWmonitor temp shows the "TMPIN4" and "AUXTIN" to be over 100 degrees celcius .. what are they? and why are they so high? -- my asus monitor doesn't show anything outside of mobo+cpu so I can't compare the temps.
You got an IB. That's your problem. Reseat the IHS and apply some new thermal paste and you're golden.
