Hey everyone,
Not sure if this is better suited for this forum or the audio section, but I see this is more of a Linux issue than a headphone one.
A couple of weeks ago I bought a cheap Logitech G230 headset. They sound good but I can't get decent mic levels. I'm running Antergos (Arch) with Gnome 3. The motherboard I have is a Asus Z87-K with a RealtekĀ® ALC887 8-Channel High Definition Audio CODEC (copied from website). Pulse Audio sees everything, but the mic volume is too low and when I amplify it within Gnome's settings, there is a lot of static. I have tried using front and back ports. I found something on the Arch wiki about changing the rate and it didn't solve anything.
I have an older Creative PCI sound card I could try if I need to. Problem with it is the lack of compatibility with my HD Audio connectors on the case.
Any suggestions?
