Headset or Headphones
I am looking at getting a new gaming headset, but i read that a good pair of headphones with a separate mic is better. can anyone tell me why it's better i am not an audiophile so i wouldn't know. and if you can recommend me a good set of headphones for the price i would appreciate it.
or if you disagree with that statement and believe that a headset is just as good, if not better can you recommend me a good headset for the price.
I am looking at spending no more than 60, but if you can convince me of ether a headset or set of headphones that is a little more i will consider them.
-TheBirdMan2012
Well, basically, with headsets, the manufacturers aren't putting great quality components in there, so you are buying more for convenience with the integrated mic. If you are only gaming, that is fine, but with a static mic, you will have the free-range to choose the quality of audio you want to record, and the quality of audio you want to hear. If you want a shit-tastic mic, but $500 headphones, then you can prioritize; same goes if you want to buy a $500 mic, and get cheap ear-buds.
Do you have any recommendations on a good set of headphones then?
it depends on what you want and what you want to spend.
if you want something cheap but good get the koss porta pro's. they sound decent. i like wearing them on the go.
for gaming i really like the ath-m50 - they are about 150€ - and they sound fantastic.
here is some reading material
http://www.head-fi.org/a/headphone-buying-guide
http://installgentoo.wikia.com/wiki/Headphones
