Headset & Monitor 24inch
Hello everyone
I am need of a new headset as well as a new monitor. So that you guys can help me make an educated decision here is my background and what I will be using them for.
Currently I own an Accer 24inch LCD(nothing special) and a Broken Logitech G35 headset( I want to get away from Logitech if possible seeing how this was my 2nd set of G35 that broke)
I do play a couple games namely Rust Alpha and occasionally an RTS like CIV 5 or Anno
My main occupation is Software Development working in visual studios and collaborating with other developers through Skype or Google hangout. I tend to listen to my Pandora station while I am working.
Priority as far as importance for me. Budget $400
Headset
  1. Long term comfort
  2. 7.1 sound quality
  3. durability
  4. mic quality
Monitor
  1. At least 24 inch
  2. Adjustable tilt and height
  3. Display port, HDMI or DVI input
Get some wood and DIY a custom Stand for all of your tilting needs look at samsungs range for monitors and have a look through razr's headsets hope this helps
bump
Sony MA900's , A900X's or DT990's with an amp/DAC. Get a clip on mic from Zalman (ZM-MIC1)
If you really are dead set on getting an all in one "gaming headset", the PC360's are really the only valid choice. Anything which is a "7.1 gaming headset" is going to be awful, research them online and you'll find out why
I have a BenQ XL2411T 144Hz monitor that's really nice, pretty pricey though
I just got my Asus Vulcan ANC yesterday, and i have to say they are awesome! The mic quality is good, the audio is god and they are really comforteble, i had them on for like 5h and i forgot i even had them on . I dont know how durable they are, but they come with a protective case which should protect them quite well. The only comlpaints i have with them is that they require a battery and it gets alittle sweaty around the ears.
