What is a good headset? I need a mic that does not pick up static, preferably $50. Maybe a little more if it is totally worth it.
It can either be a headset or mic.
Your not going to find a nice mic on a $50 headset. But here are some Decent options
http://gaming.logitech.com/en-us/product/g230-stereo-gaming-headset
http://gaming.logitech.com/en-us/product/g430-7-1-surround-sound-gaming-headset
The Razer Kraken Pro, $79,99.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826153112
The Logitech G230's are also a good option.
I also asked for just mics. Are there any good? I was looking at the Snowball, but was unsure. I would rather not have a headset, as I already have some good headphones.
I use the blue snowball, here is a sample video I made as a inbox.exe video question a while back using the blue snowball http://www.youtube.com/watch?v=FQ6cuDBaM1c
As you can tell its very clear, the static you here isn't really static, It my computer fans so...
