I am having a bit of Audio trouble with popOS 20.10
For some reason I can get audio through my headset (whether plugged into the front panel or using the rear input), but no matter what the microphone is not getting recognised.
Tech Specs:
CPU: Threadripper 3970x
Mother Board: Assus ROG Zenith II Extreme Alpha
GPU: Nvidia RTX A6000
Headset: Sennheiser Game Zero
I have tried everything in pavucontrol and alsamixer.
If I run hdajackretask it only displays the Nvidia sound card.
I get this when I look at the cards
cat /proc/asound/cards
0 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xe7080000 irq 157
1 [Audio ]: USB-Audio - USB Audio
Generic USB Audio at usb-0000:49:00.3-5, high speed
2 [Audio_1 ]: USB-Audio - USB Audio
Generic USB Audio at usb-0000:49:00.3-6, high speed
and the only codec in the system is this:
Codec: Nvidia GPU 9a HDMI/DP
Ironically if I change the preferences in Audacity to use:
USB Audio: #1 (hw:1,1)
or
USB Audio: #2 (hw:1,2)
It will actually pick up the mic input if it is plugged into the back or front ports respectively, but this just doesn’t seem to translate to anything that i can set in pavucontrol.
Is there a HD Audio driver for amd that needs to be installed some where?
