Headphones question
Hi, i'm looking to have my headphones connected to my Xbox 360 and PC at the same time, the headphones I want to do this with are the Audio Technica AD500x's, would a Astro MixAmp be a good solution? Is there a better solution? Will this even work? Please respond, thanks!
If you don't mind having the PC on to be able hear the Xbox you can connect the Xbox to the line in on the PC with some adapters and go into recording devices and find line in go to properties and set it to listen mode. Then you should be able to hear both the PC and the Xbox on the same headphones and also adjust the volume independently with the volume mixer. This is what i do with my Xbox i have it connected to one of my monitors secondary inputs and whenever i want to play something on my Xbox my PC is on anyway so it works rather nicely.
