Headphones for travelling
Hey guys,
I was looking for some closed noise isolated headphones and came across the beyerdynamic dt 770 pros and the sennheiser urbanites. Any better that you know of?
-Binary
What's your price range (I'm assuming $200-$250 based on the cans you mentioned)?  What's your source?  Will you be amping?  How portable would you like them to be?
I am using an HTC one with no amp. The price range is fine and I would like them to be portable.
I use px 360 BT's from sennheiser, good sound and the bluetooth is useful as you don't need cables getting tangled up in bag straps etc. Plus if they run of charge you can then use the cable so you can still listen to tunes. Battery life is good, having controls on them is useful as it saves getting your phone in and out of your pocket etc, hope this helps :)
