Headphones for around €80
Hay I'm looking to buy a headset for around €80 and I need a few suggestion since I know sweet feck all about headsets.
I'd like something thats a bit durable since I use my headset a lot and posible a changeble cable but thats not very important.
Thanks  for any help.
Nerakai
Roccat Kave
tom
I was looking at that before but honestly it doesn't look very durable, I've had the Roccat Kone before and it didn't last very long before it keeled over so I'm not very trusting of the company.
Nerakai
I've had the GameCom 780 for over 4 months now they are really nice! 7.1 surround sound. and comfortable  they say that they are very durible and they are. I drop them once or twice a day.
One day I forgot I put them on my chair to clean my desk and I sat on it. I heard a snap and I put them on and nothing happened the next day I put them on and they broke where the speaker swivles. I got a replacement through bestbuy though. I like them sound quality is just so awesome!
You may or may not like them depending on how you like your headphones be, the speaker shape is like squares so its a bit weird I got used to them though.
The sound is also loud, most of the time you have it on the lowest sound setting. Also the mic is muted when you get them in the box.
Thanks man, I just looked up a few reviews and heard good things about them and luckily I found them on sale too.
Nerakai
Brainwavz HM5 - has replacable cable, is durable, except it doesnt have a mic. Great sound quality too.
