Headphones for $100. Gaming or Regular
I have a $100 budget for some headphones so i can listen to music and play games with them. I want a pair of headphones that i can wear  for a long time and will be comfortable. They do not have to have a mic but they can as well.
For that budget, I would go for the Creative Aurvana Live headphones. They're  pretty decent all around headphones, for both music and gaming.
Beats!
Plantronics Gamecom 780 is pretty, good, I've been using it for nearly a year now. Really light, big ear cups, nice sound/microphone quality, loud, and the "virtual 7.1 surround sound" is actually pretty damn accurate for gaming.
Only issue I have with them is that they have nearly 0 noise canceling effect. Putting them on has no real effect of muffling outside noises, and the lack of an EQ in the drivers.
do you need surround sound for gaming if not these are a great pair of listening headphones as well as the occasional gaming.
http://www.amazon.com/Shure-SRH440-Professional-Studio-Headphones/dp/B002DP1FTU
I really love my Sony XB500's for just listening to music. They sound great when paired with a nice sound card and some type of EQ, the highs can get a little muddy. Those paired with a mod-mic probably wouldn't to bad.
You could also go with one of Corsair's new headsets, they seem to be fairly cheap on Newegg and sound quite good to be honest.
First things first, never buy Tritton. They sound bad. They will break. They are the most expensive decorative pieces I have ever owned.
Check this guide on head-fi out: http://www.head-fi.org/t/534479/mad-lust-envys-headphone-gaming-guide-updated-9-2-2013-sony-ma900-added
I have a pair SteelSeries 7H and they aren't too bad at all.
Little low on volume with the on-board sound card and they have some mic feedback issues, could just be me though. No complaints on build quality or comfort.
Have used Razer Carcharias until the headband wore out after years and never had a single issue with sound/mic quality. They're good headphones, not great.
Razer Tiamat sounds awesome when you play Battlefield. Pure chaos. A friend of mine has a pair but somehow they died out. Not sure what happened but it seems like it had a short when he plugged the USB in. He's using my old set of Carcharias now lol.
EDIT: Looking at getting the Corsair Vengeance 1500 next, they have pretty great reviews.
I got those for gaming and travelling a few months ago and they have awesome sound quality. However I wouldn't recommend them, wearing them for more than an hour and a half starts to hurt my ears. Maybe my ears are just too big but I'd just pick another pair.
If you live with other people and want to have closed headphones, go with the JVC HARX 700; http://www.amazon.com/JVC-HARX700-Precision-Sound-Headphones/dp/B0013OWPV4/ref=cm_cr_pr_product_top
They aren't the best or most expensive, but you can always get a higher-end pair of headphones at some other point if you feel you want better sound.
If you live alone and don't care if you have an open-headphone design you can go for the AKG K240. These are a bit higher priced, but you get a lot of features you expect to see on $200+ headphones. http://www.amazon.com/AKG-240-Semi-Open-Studio-Headphones/dp/B0001ARCFA/ref=sr_1_1?s=electronics&ie=UTF8&qid=1380760538&sr=1-1&keywords=akg+k240
I can vouch for the JVC HARX 700s.  Once they break in, they sound very good and balanced for the price.  They are also semi open so you get that massive sound stage.    Just be aware that they are enormous, and unrealistic for anything other than listening at home.
