Depends on the budget, on your amp (or lack thereof). If you want to be able to listen to a wide variety of music, then the typical open, competitive fps headphones are NOT for you. Those lack bass....... by a lot. If you want something for all genres, then I would suggest something with either a fun or a neutral sound signature. That is hard to come by under $100 if you insist on open. The Fidelio L1 end up on massdrop for ~$100 every now and then though. That would likely be your best bet.
