So I recently picked up a Micro pc that has very minimal specs but I believe would make a nice media box that can be stuffed in a drawer or under my tv. Its running a Intel Atom 1.6ghz dual core processor with 2gb of ram, it only has VGA out and I'm wanting to use it with HDMI instead. No there really isn't any way to upgrade it, it only has a PCI slot on the mobo and the case its in doesn't even really allow for a card to be used in it.
So I'm looking at this on amazon http://goo.gl/nNeFVP seems to be a possible option but since its ran by software I'm worried it would bog down the processor, I'm not familiar with how it really works.
Or I could go with this on newegg http://goo.gl/XlcM8n Which only takes power from usb and uses the VGA out to get the video signal.
What do you guys think would be the better choice, or do you possibly know of a different method to getting HDMI from this machine?
