Hi everyone!
in my new PC i have 2 kingston hyperX 3K and a WD 1TB Black.
the 2 ssd's are ine raid 0 and it works, but the non raid disc (the WD Black) does not show in windows but it does in the BIOS
Motherboard: Asus Rampage IV Black edition
Hi everyone!
Open up Disk Management
Is it there?
You may have to format it to get windows to recognize it.
iirc If it's there you can right click it in disk management and format it
no it s not even there in windows
rectification it s in periferials manager but that s all i can t do anythig with it
assuming the black is a new drive without usage you'll have to format it through disk managment
http://windows.microsoft.com/en-us/windows/create-format-hard-disk-partition#create-format-hard-disk-partition=windows-7
Does it even show up in disk management? if it does do that.
Don't format if you have data on the drive. It will be lost
you might have to set up the single drive as a single drive in your raid bios.
so it showes up but it says ti s for the system and it has 1Go of free space
download a live usb of linux and run gparted
use gparted to format the drive
